Case Suggestions for Super-Workstation
nitrobass24
[H]ard|DCer of the Month - December 2009
I am building a new workstation soon and wanted some input on cases.
I know I am building a heat monster, but I would like to keep it as quiet as possible.
This will be a Dual Xeon nehalem box with 4 double GPUs.
I am thinking for CPU coolers to go with either two TRUE Blacks or two Corsair H50s
Must Haves:
8+ expansion slots.....will be using 4x GTX275's
E-ATX support
Space to mount 2 H50's
I have looked at the Corsair 800D and I like it but I dunno how I could put in two H50's
What you guys think?
Instead of using 2 seperate small watercoolers, just use one large loop or two loops of traditional money. If you have the funds to purchase 4 gtx275, you probaly could afford one and it would be quieter or just as quieter as two seperate HSFs and you'd get better temps
Good Luck
Yea, im looking for something.....well normal looking. I dont really want a spaceship in my room.
You could stick an H50 on the top of the corsair 800D (Or both of them?) Just space them out a bit... or one on back one on top..
Hmm welll I think I might just go with air cooling.
Looking at the Armorsuit P50 but im kind of concerned about cooling ability.
I really like the PC-A7010, but it only has 7 slots and im not sure if there is enough room for my 4th GPU.
I would prefer to go with Lian-Li, they make great cases.
After reading about the cooling issues on the 800D, while its not terrible I dont think its up to this task.
Temps are identical to my HAF922 I had... but this case is silent in comparison and is running 3 x 140mm fan's vs. 3 x 200mm, a 120mm, and a 140mm...
I will try a different airflow if I have time that some people say might improve airflow even more
BlazeStorm-
I currently have a Gigabyte Aurora 570 case and I think I would like to go to the HAF 932. Do you think it would provide better airflow than my Gigabyte?
Thx
Sorry to the OP for the thread heist......
