Case suggestions for my system
Hi I was looking for some suggestions on cases for my set-up. I'm looking for a case at around $100-150. I would like it to have good cable management and be a durable design. I will be doing some overclocking so good cooling is important. Some of the cases I am thinking about so far are the Fractal Midi, Corsair 500R, Haf 932. This is what I will be putting in it:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182133 Rosewill Hive 750w PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697Seagate Barricuda 1tb hd
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231558 G.SKILL ares 16gb DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102982 Saphire HD7970 OC version
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148442 Crucial M4 128gb sata III SSD
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181017&Tpk=corsair h100 Corsair h100
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128545 Gigabyte GA-Z77X-UD5H
I'll be using one of the new Ivy Bridge I-5 Chips
Any suggestions at all would be appreciated. Thanks!
Thanks for the suggestions, but I'm more looking for things people have personally used and found to have fit the h100 and have good cooling. I know cases are a lot about personal preference but I also would like a case with a good track record of cooling that people have experienced.
