Case Side
W.Feather
[H]ard DCOTM x4 & [H]DCOTY x1
I am working on setting up my first mod, which will be quite extensive if I can do it all.....I have a few questions though:
1- Where can I find a new solid side for the Antec 1200 Case ??? ive looked all over , and can find one for the Antec 900, but not the 1200.......I plan on cutting a custom side.
2- Is there any good way to replace the front of the case with a solid front ??? ive got an idea going, not sure the best way to mount a solid sheet in the front.
3- Where is a good guide to Sleaving?(Ive been looking through alot of work logs and am amazed and the stuff done with sleaving the power cables)
Been a fan of this forum for a while, finnaly got around to registering, love some of the mods that have been done:)
*For #3 i did not look at the search function, it came to my mind right now as I was typing this message
you could probly get another full side door from antec if u really need it. solid front? not really sure why you would wanta solid front. might wanna make some drawings and post them up. the 1200 case was designed for airflow. this is why its full of holes. i sliced up the side door on mine the first day i got it cuz i wanted a proper window, but that was all the major modding i did to it.
well, im not really looking for a "solid" front....more of a staggered solid front, with like 4 slats on the front that are overlaping with space in between them in the verticle direction (when i get back to my rig ill make a image of what I mean, cant really describe it), there will be plenty of room for air to enter in it from the way it is in my mind atleast......
my last resort was to contact antec directly(figure it would cost an arm and a leg b/c it might be considered a "custom order" if they did it at all)
