Hey Guys
Finally got around to building a computer, please keep in my I am new to this and not that knowledgeable on this.
I have a few questions concerning CPU and GPU temp's and what I should be getting with my setup, and possibly if I should move my PSU from the bottom of my case to the top.
Specs:
Case
C-A70B
CPU: Intel E8400 (slight OC to 3.6)
Headsink/fan: Zalman 9700 (copper one)(arctic silver 5)
HD:150gig WD Raptor
GPU: Evga 9800GTX
PSU: Antec quattro 1000watt
Mainboard: 780I
Now I am using real temp 2.4 to check my cpu temp's and I seem to be ideling around 36-37-38. Underload it can go up anywhere around 44-47-48, room temp is most likely around 75-78 and this case has quite a few fans and I can feel the air pushing threw it.
My GPU is running at around 60-63...Are these temps normal? Should I be getting much lower temps with this setup?
Only thing I can think of is the PSU at the bottom of the case is causing heat to rise up. Also my zalman will only fit in 2 ways on this case because of its side, if I faced it straight up it would be blocked off by the top chamber where theres a fan but can be fitted for a psu. So I had to face the fan downward facing the northbridge fan.
I have a picture I will include in this post, in the picture I had the video card in a different slot and had to end up moving it to slot 1. Since its in slot 1 now the video card is right next to the northbridge and cpu heatsink/fan. Only thing I can think of is that the zalman is sucking in the hot air coming off the gpu and pushing it onto the cpu.
Anyways, sorry for suck a long post but I wanted to make sure I get the best cooling with my setup and make sure I did everything right.
Appreciate all the future replys and thank you for taking your time to read this and help me out.
Specs:
Case
HD:150gig WD Raptor
GPU: Evga 9800GTX
Mainboard: 780I
