So my computer travels around. To the neighbor's, to LAN parties at friend's houses, to school. And as a result the case badly scratched. The case in question is a Thermaltake Armor Black tower. The sides (especially the non-window side that I flip it onto to do maintenance) are gouged.
What can I do to fix this and prevent future problems? I had someone suggest the following:
- Run ScotchBrite pad
- Spray on primer
- Spray on engine enamel
Open to suggestions, try to keep it cheap though!
- Spray on primer
