Case recommendation
johnny555
Hello,
I currently have a Lian Li Lancool II with an AMD 3800 cooled by an ARCTIC Liquid Freezer II 280 and an air cooled 1080ti. I recently hit the queue for an Evga 3080ti Hydro Copper card. I picked up a Bitspower Smart Combo Xtreme 240 all-in-one cooler for the video card. I'm not seeing how I can fit it into the Lancool II so am looking into upgrading the case. Would a Lian Li O11 Dynamic XL handle it? Any other cases to recommend? thanks.
You should be able to fit that in the XL. I have 3 360 radiators in mine, and I think it can accommodate 280 radiators in lieu of a 360.
I would consider just going with a custom loop though
Thanks, I'll go with the XL. It was the case I was originally going to go with when deciding on the Lancool II but I didn't think I'd need the extra space and never thought it would be so difficult to pick up a new video card. I may do a custom loop but wanted a quicker solution until I have more time to research it and plan it out.
