Im building a PC and I only need one more item, the case. I know that I need an ATX case. With the below mentioned parts, should I get a full tower or a mid tower (Im especially worried about fitting that Hyper 212 Evo)? My budget is $200 max. Features such as noise reduction, removable storage device trays and cord management are important to me. Conversely, I would prefer the case had minimal or no LED lights (would keep me up at night).
CPU: Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Motherboard: ASUS SABERTOOTH Z77 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131821
Video Card: EVGA GeForce GTX 670 FTW 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card 02G-P4-2678-KR
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130787
Hard Drive: Western Digital Caviar Black 1 TB SATA III 7200 RPM 64 MB Cache Internal Desktop Hard Drive Bulk/OEM - WD1002FAEX
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
CPU Cooler: COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel 2011/1366/1155 and AMD FM1/AM3+
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
SSD Hard Drive: Crucial M4 CT128M4SSD2 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=20-148-442
Memory: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Profile Desktop Memory Model CML8GX3M2A1600C9
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233186
Optical Drive: Lite-On LightScribe 24X SATA DVD+/-RW Dual Layer Drive IHAS424-98 - Retail (Black)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106335
Power Supply: Corsair AX760i Modular 80 PLUS Platinum Power Supply (Not Yet Available)
http://www.amazon.com/Corsair-Professional-Digital-Platinum-AX760i/dp/B00A0HZMI8/
Case: ?
Case: ?
