Case Recommendation
drozenski
Im looking the following case.
Needs to have 8 internal HDD drive bays.
or
6 External drive bays so i can fit 2 drive chaises in them.
Any one have anything stylish that fit either one of these? Also smaller is better. I would prefer a smaller case over a bigger one, no server cases please. the rack mountable type.
i found http://www.newegg.com/Product/Product.aspx?Item=N82E16811163001
But am wondering if anything better exists.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119152
http://www.lian-li.com/v2/en/product/product06.php?pr_index=135&cl_index=1&sc_index=26&ss_index=65
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112131
http://www.silverpcs.com/index.php?cPath=2_38_94&osCsid=2ebdab3d71020c1aca46c1cbbb83fdcb
check silverpcs if you want the silver version of the lian li
the cooler master seems to have great cooling with the two top fans, bottom mounted psu and 9 bays.
Im in search of a micro atx case with multi bay design, bottom mounted psu and top fans. the size of lian li A05 like this
http://www.silverpcs.com/product_info.php?products_id=164&osCsid=2ebdab3d71020c1aca46c1cbbb83fdcb
