Case question
usb
I am wondering about my Roswill Challenger case. It looks like crap on the inside. I want to get a 670 ftw graphics card and was wondering if it would fit this case. Maybe not with the way I just have wires all over.
What is a good mid size case under 100 bucks that would fit larger cards in the future?
I am debating to get one now with the card or just get the card, try to fit it and later when I upgrade other components get another case. Would that be a better route?
https://www.dropbox.com/s/vsix8ebre4v088k/IMAG0214.jpg
Well you could start by managing the cables in the case now.
Then get a tape measure and see how much room you have.
Seems like with my msi 560ti I it was 9.5 inches and I had some room left, about .5 to 1.3 inches left. I wish I had tape measure here with me. I saw a post on here long ago where someone fit 2 670's in the challenger.
