Case/Power Supply suggestions.
wildzcardz
Well I am doing my homework for a SFF pc. I think /i am set on a I3 560 w/ Gigabyte GA-H55N-USB3. Basically I want to use this for surfing the net and media via movies. Going to add a blu ray drive, 1 SSD (most likely a Intel X-25 40GB) and a WD 2TB Green HDD for media storage.
What I want is the smallest case with 1 expansion slot for a ceton cable card tuner and a power supply that can handle all this. Suggestions please?
I like it, just looking for a slim design, hoping to find a power supply I am thinking maybe 200watts should be plenty for the system.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811108196 ?
Learn more about the In Win BP655.200BL
Model
Brand
IN WIN
Model
BP655.200BL
Spec
Type
Mini-ITX Desktop
Color
Black
With Power Supply
Yes
Power Supply
200W
Motherboard Compatibility
Mini-ITX
Expansion
External 5.25" Drive Bays
1
Internal 3.5" Drive Bays
1 x 3.5" HDD (1 T)
1 x 3.5" HDD (0.8 T)
Expansion Slots
1 x Low Profile Card Slot
Front Ports
Front Ports
USB / Audio
Cooling System
80mm Fans
1 x 80mm fan
Physical Spec
Dimensions(L x W x H)
12.20" x 10.40" x 3.90"
Features
Features
Security: Padlock Loop / Kensington Slot
Easy Integration
Optimal Thermal Performance
Standard TFX 12V Power Supply
Standard Components
Tool Free
I was looking at that, but I have heard alot of those PSU that come with those cases are junk. I could order that one and if and win that PSU died upgrade it.
Hm well I wouldn't be surprised although the the SFX ones that come with the Silverstone cases are solid from what I hear.
Well all I know is that you can purchase the ST45SF which is a 450 SFX PSU (which is more than sufficient for your needs and what you wanted) from retailers like Newegg.com or Amazon.com but it's expensive ($79.99+).
Since you're just watching movies and browsing the net, would you perhaps consider an AMD Athlon x2 build? There shouldn't be any difference with those two uses and it'll save you a bit of money. :)
