lillimon04
- Oct 24, 2006
Ok Im building a case in my shop class, and I was wondering where to get a mobo tray and a psu bracket? Is there only the lainli tray to buy and the psu brackets at frozencpu? Or are there more to buy? And How do i make a 5.25 bay cage for one and a 3.5 cage they will be on top of eachother. And how do i make a big 3.5bay cage for hdds it will go in front of a fan.And should i take pics when i get started to make a work log? I could ask my teacher if he will let me. I have been wanting to build this case forever, and some dude made one like one i wanna make, it was the UFO, its in the worklog part. But my case is gonna be 10 inches tall and 14 inches long. Two 120mm fans in the front, One in the back above the mobo, and then a psu over the mobo too( like where the pci brackets are) Is that a good case? Or should i go m atx mobo and have the psu on the side of the mobo like other regular cases?
This is my mock up on paint, on AutoCAD it looks soooo much better, but i dont have it at home, only at school.
Front
Side, and its 14inches long.
back
Also were should i put a hdd cage? i was thinking in front of the back 120mm fan, so that it hangs. The side panels are gonna be plexi and the top, the bottom front and back are gonna be metal.
Front
back
