Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Can anyone point me to some good case painting tutorials. I will be painting the inside a flat black and want to know how to prep and paint the inside.
Thanks
Yes his instuctions were very good. I only plan to paint the inside, so his instructions dont work as well from a bare metal standpoint. Just wondered if any sanding was needed and with what grit and if primer is really needed. No gloss coat for me, just going for a dark inside (flat or matte) so my UV lighting looks flashy on the cables and such.
