I've got some spare time and a bit of cash, I was wondering what I would need to get started on painting my case, I've got a noname case i got for 45$ CND, it looks sorta like a space ship with a handle up top...
parts of case
handle = plastic
front = plastic
side panels = steel
What would i need to paint these? I'm thinking i would have to sand the original paint off the steel then use a primer and then the colour i want (probably white then logo on the none-window side) cuz i was thinking 220~ grit sandpaper and lots of krylon paint
p.s. i'm also curious about the plexi window it has, i want to make the window blurry or fuzzy, could i use high grit sanding paper to get a blurry effect on the plexi glass?
p.p.s. i've done well with wire management and have taken apart the front plastic cover, all the parts can be taken off without issues so i can paint pretty much every part of the case... plus i have a backup comp and case i can shove my parts in so time is not of issue
thanks in advanced i hope i conveyed what i'm trying to do properly.
Luis
parts of case
handle = plastic
front = plastic
side panels = steel
Luis
