Case Opinion
Could someone post a link to a good case that has the following:
1.) Under $110 dollars
2.) Has a top fan opening
3.) Has NO door covering the drives that needs to be opened
4.) Has a side window
I have been looking around, and so far the only one I can find is this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
However, it is just out of my price range, and I would like something else to compare it to with the above criteria.
Thanks guys
If you wait you can get that case for about $60 is the lowest I've personally seen it.
