case - motherboard compatibility
Simple
Im looking at a HTPC case for a full sized ATX motherboard. what like 12.6 x 9 inches or whatever, however big a decent motherboard is. The thing that i am curious about is this lian-li case that is horizontally aligned on newegg but inteerstingly not called an HTPC case that is super deep and so i was looking for something less deep so it would fit on my desk and i found a silverstone which is much less deep. Problem is, the place for the mobo looked small to me but it says it accepts standard a micro ATX motherboards. the lian-li says that its motherboard size is specificallty 12.6 x 9 ATX like there is a difference between standard ATX and this bigger size?
Will a full-sized motherboard fit into this case?
