I have a couple year old Antec Dragon case that my buddy gave me as barter for helping him setup his server in his house. Over the last year I have been working on modding when I have gotten the chance. I have only gotten as far as a basic plan of what I want and the starting of a paint job. Problem is I want to increase the air flow in it with some 120mm fans. Now as most of you know the stock holes are 80mm and I would like to change them to 120mm but doing so I will lose the 2 harddrive brackets/cage holders in the front. I am not of a designer so i dont really know what I should do in terms of designing another harddrive cage and secondly do I really want to lose the functionality of those cages. I dont have a template to use as a guide to where to cut the wholes and line them up.
Should I completely get rid of the front HDD cages and build my own HDD rack and replace the 2 front 80mm fans with 120mm. Or should I just use the top HDD rack and cut the bottom fan out for the 120mm? Will this cause any negative pressure in the case or any turbulence?
Thanks for info/suggestions.
