Case Mod (How to?) fan/light Switch
scrooloose
I am looking for a tut on how to make a fan/light switch using only one molex connecter to power it. I found one before but cant seem to find the link that I had. Any suggestions.
not sure what you mean but if your just saying you wanna control a light or something on a molex connector with a switch, just put a switch in between the circuit....
for example, 12v goes into light, ground goes out.... you can put a switch on the 12v input wire
