[Case Mod] Aero Cube
Discussion in 'Worklogs' started by Dirk Kramer, Jun 19, 2017.
  1. Dirk Kramer
    Dirk Kramer n00b
    13
    May 7, 2016
    Hey enthusiastic PC builders,
    I'm going to start a new casemod, this time a micro-ATX build in the Aerocool DS cube.
    It has to be an HTPC that can also be used as a LAN-box, so it has to be a freaking awesome case.
    Hardware : not known yet
    Cooling components: Not known yet
    Here are some pictures of the Aerocool DS Cube.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Playing with some LED`s.
    [​IMG]
    [​IMG]
    See you soon :cool:
  2. Logan321
    Logan321 [H]ard|Gawd
    1,902
    Oct 9, 2003
    That case fits a matx motherboard. They're usually cheaper and have more features than the comparative mitx board. Just a thought.
    Also, needs handles if you're going to be packing it around. ;) have fun!
  3. spugm1r3
    spugm1r3 [H]ard|Gawd
    1,171
    Sep 28, 2012
    It looks like it has a recess on the back for a handle, I'm supposing you grab the bottom with your other hand. Some proper handles sure would make it easier to lug around.
    I agree on mATX, way more bang for your buck. mITX is fun, but only if you have a case nothing else will fit in.
  4. Dirk Kramer
    Dirk Kramer n00b
    13
    May 7, 2016
    This week started making a midplate and some minor adjustments to the case itself ;):
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Pre-drill the holes and then cut out with the cutter.
    [​IMG]
    [​IMG]
    [​IMG]
    Mid plate fits perfectly :D:
    [​IMG]
    [​IMG]
    [​IMG]
    I made a window in both side panels, here you can see the graphics card en later the cooling en hardware.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Problem ?? Little space for power cables,s o I did a little adjustment.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Did some wrapping on the midplate with some mat black.
    [​IMG]
    [​IMG]
    [​IMG]
    I got the idea of making a pump with reservoir combo in the front of the case, so the round hole has already been made.
    Had two more pass through fittings spare, so I used them to make an easy connection through the midplate.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    pendragon1 likes this.
  5. Dirk Kramer
    Dirk Kramer n00b
    13
    May 7, 2016
    Hey, another update.
    This week I started with the front panel of the case.
    I used the Asus Mayan pattern for the front, later on there will be a lot of RGB led`s behind this panel and case parts.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Used some primer, more in the next update
    [​IMG]
    If you have any questions, I'd love to hear those :D
  6. Logan321
    1,902
    Oct 9, 2003
    Did you do all that cutting by hand? That's some pretty amazing attention to detail.
  7. Dirk Kramer
    Dirk Kramer n00b
    13
    May 7, 2016
    Yes, I've cut it all out with a fretsaw. Thanks :)
    Derf likes this.
  8. Dirk Kramer
    Dirk Kramer n00b
    13
    May 7, 2016
    I got a new tool for modding, bought this airbrush starter-pack with some paint to get started.
    For a first time I did a nice job I think, of course there are some points we can improve but we can work on that.
    [​IMG]
    [​IMG]
    These colors I`m going to use on the case. (red madder dark, black)
    [​IMG]
    [​IMG]
    [​IMG]
    First I used the color (red madder dark), then I used a airbrush and brush and added the color (black). And added a clear coating, for a first time I did a great job I think.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    The sharpness of the pictures will improve in the next update.
    revenant and Derf like this.
  9. DeathSmasher
    DeathSmasher Limp Gawd
    439
    Apr 14, 2006
  10. wra18th
    wra18th [H]ardness Supreme
    7,751
    Nov 11, 2009
    Sub'd! Interesting.
  11. Dirk Kramer
    Dirk Kramer n00b
    13
    May 7, 2016
    Thanks :D
  12. Dirk Kramer
    Dirk Kramer n00b
    13
    May 7, 2016
    So I got two packages last week, one with all the hardware and one from Highflow.nl with all the cooling parts. So let`s get started with the inside.
    [​IMG]
    MB: Asus ROG Strix Z270G Gaming
    [​IMG]
    [​IMG]
    CPU: Intel Core i7-6700K
    [​IMG]
    GPU: Asus Strix GTX1070 O8G Gaming
    [​IMG]
    [​IMG]
    RAM: Avexir ROG Tesla Red 2666 MHz 16GB
    [​IMG]
    [​IMG]
    PSU: Corsair RM850I
    [​IMG]
    And of course ''CableMod''
    [​IMG]
    [​IMG]
    [​IMG]
    For cooling I chose EKWB
    [​IMG]
    EK-FC1080 GTX Strix – Nickel with a shinny Nickel Backplate
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    EK-Supremacy EVO – Nickel
    [​IMG]
    A group photo
    [​IMG]
    It`s time for some PETG bending
    [​IMG]
    EK-XRES 140 DDC 3.2 PWM Elite – incl. pump
    [​IMG]
    [​IMG]
    [​IMG]
    Best handy tool ever, no sharp edges anymore.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Derf likes this.
  13. Dirk Kramer
    Dirk Kramer n00b
    13
    May 7, 2016
    It took a while but here is the final shoot of this Small Case Mod.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    bigmac11, shadowlord, wra18th and 2 others like this.
  14. wra18th
    7,751
    Nov 11, 2009
  15. Dirk Kramer
    Dirk Kramer n00b
    13
    May 7, 2016
    Thank you ;)
  16. DeathSmasher
    439
    Apr 14, 2006
    Is there a way to make the pics show up in the thread or do you have to click on each one?
  17. pendragon1
    pendragon1 [H]ardForum Junkie
    10,699
    Oct 7, 2000
    nope. he linked them instead of drag and dropping them...
    DeathSmasher likes this.
