Case missing standoff's?
PsychoFanatic
so i recently purchased a DFI LP LT P35 T2R MB
and alll my stuff came today
only to find out it seems i'm missing standoffs for my raidmax Smilodon Extreme Black case?
i have 8 and the MB has 10 holes, now i have a question can i install my MB without having the other 2 standoffs or will that be impossible?
yea you can do that, but you should go to a local or go to the geek brothers or whatev at bb and ask for a couple. if you have to leave 2 out, leave the ones out where there will be the least stress on the board, which will vary according to your setup. whatever you do, dont ever use extra standoffs.
great mb, i had the ut, which was the same with slightly diff cooling..
