Case Help
NightyNight
I need a new case, preferably one that's quiet, smaller, metal, clean looking, and black.
Right now I have a big black bulky Tsunami Dream, this thing is LOUD. I want something much quieter, and cleaner looking on the outside, I prefer no door.
My budget is less than 110, and looking at possibly a future in water cooling.
For a small case maby one of these?. Now, if you plan on having water cooling in any mini atx or baby atx... good luck. Your going to need an external kit and some patience to wire that thing in such a small area. Id recommend buying a mid sized tower and just using silent fans, and noise dampening installation. Alot of companys make fanless powersupplies. If your dont plan on running any heavy games or applications there are also fanless heatsinks you can find. Search goolge for silent computer cases. Theres alot of sites dedicated to silent PCs.
