Case help (recommendation)
c2rex
Looking for a bigger case. Priorities are interior space and airflow. I have a 750 Corsair powersupply that I will be putting in it. The case doesn't have to be pretty. I don't need a window or lights. The motherboard is full sized. Would like to keep the cost below $80 (if possible). What do you guys recommend?
At that price point, your best bet would the Corsair 300R case.
