case fro water cooling?
Malikman
hey what size case should i get if i want to watyer cool my system i was thinking i was going to go matx SSF case but i'm not sure anymore... idk what to choose any thoughts! i need to kno so i can choose my mobo and case
i think you can use search to find some better results but...
although i don't water cool yet, the stacker seems to be a promising case.
i have one myself and it is HUGE!
it has plenty of space for a radiator.
try the gigabyte 3d aurora. it has 2x120mm exhaust fans on the back and enough extra room so that you could install a 2x120mm size radiator inside or outside. also has 2x 1 inch diameter holes pre drilled on the back panel with rubber grommets for safe water line routing. its also a pretty big case, but not as big as the cm stacker.
that thing attached to the top is just a cheap mod i did.
what about the coolmaster centrunio 5 is that a good case for WC (the version with the window)
Whatever case you decide upon...I would recommend the CM Stacker ST01, BTW...don't forget to factor in the space needed for tubing.
Especially if you go with a largebore system (1/2" tubing), allowing for the bend radii can eat up a LOT of room.
a somewhat biased vote for the CM stacker.
Beyond it's versatility and size, I thinks its very well built and also comes with more screws and other hardware than you'll ever be able to use... including some gigantinormous wheels you can put on it and go off-roading... but seriuosly, those things are bigger than the wheels on my chair.
