I'm looking at getting rid of my rather cramped setup in my Antec Sonota...
Case has a great layout, and I'm really happy with it, but with all my hardware in there, it's absolutly IMPOSSIBLE to work on anything without taking the entire weekend...
Case requirements are 2 120mm fan mounts with enough space around them for the fan and 120mm rad (B.Ice Ext.) without getting into a messy clearance issue with anything...
Now, I'm assuming that basically all cases with 120mm fan mounts based on the ATX spec will have a clearance issue with the CPU hold down (using maze4 with spring retention) that will require me to shave down the mounts some... not a huge issue for me, as that's what i've been doing with my current setup... just makes removing the waterblock a little fun...
I've been looking at a few cube cases, and only one really looked like it would work the CK1100 Here
as far as full tower cases, the recent Rage3D review of the CM Stacker STC-T01 Here looks promising as well...
If anyone else has a suggestion that would allow me to fit my 2 120mm rads while still having room to fit a hand in the case when all's said and done, it would be aprechiated...
