dark_phantom36
- Jan 11, 2003
So, I'm looking for a case to build a fileserver in. Ideally, I would like to have a case with 10 5.25 bays, so I can get 3 sata cages that can hold 5 drives each and have a dvd drive. Sadly, most of the cases with 10 5.25 bays seem to be very expensive. I'm hoping I can keep the cost around $100, so I'm also considering cases with only 9 5.25 bays.
Here's what I've found so far:
10 bays or more:
9 bays:
I really like the stacker, but I wish I could get it for about $30 less. Here are the options I've found, so what do you guys think?
10 bays or more:
- Aerocool Coolview - http://www.newegg.com/Product/Product.aspx?Item=N82E16811196014
Looks less cheap than the linkworld case. Fits in budget. But who's aerocool? - Aerocool ZeroDegree - http://www.newegg.com/Product/Product.aspx?Item=N82E16811196023
See above... This one doesn't have bling! (good) - Thermaltake Armor VA8003BWS - http://www.newegg.com/Product/Product.aspx?Item=N82E16811133021
So many lightsExpensive. At least I've heard of Thermaltake.
- Coolermaster Stacker - http://www.svc.com/stc-t01-uwk-19.html
I'm leaning toward this one even though it's more than I want to spend. - Coolermaster Stacker 810 - http://www.svc.com/rc-810-ksn1.html
Hows this different from the other stacker? Expensive :/
9 bays:
- Raidmax X-Force - http://www.newegg.com/Product/Product.aspx?Item=N82E16811164106
This case is well within my budget. Has a stupid light up fan though.. Drive bays are toolless. - Linkworld 50201-c2222n - http://www.newegg.com/Product/Product.aspx?Item=N82E16811164106
Linkwho? Looks really cheap. Is really cheap. Will my hands come out alive?
