Ok, so I have purchased almost all the components for my first water cooling set up but now I second guessing my decision to mount the double radiator & fans on the outside of my Xigmatek Asgard Pro case. Having blown my budget on components i do not have a great deal to spend on a new case so i have short listed the following 2 cases.
Lancool First Knight PC-K63 @ £45 - great features but not the best looking. Only supports top mounted 280mm radiators not 240mm.
CM Storm Scout 2 Advanced @ £59 - looks great but features are not as good IMO. Possible support 240mm radiator top mounted.
I am hoping that some of you have had experience of these cases and can help with my questions. I am also open to your thoughts on these cases and any suggestions for alternatives in the same price bracket.
Questions -
1. Does the Scout 2 support a top mounted 240mm radiator and fans (push only)? If so what is the maximum depth of the radiator?
2. What is the maximum depth of 280mm radiator that will fit under the top cover of the K63?
I am hoping to fit an Alphacool NexXxos XT45 in the K63 hence my questions regarding depth. If the XT45 does not fit i will settle for the ST30.
If the Scout 2 is the better case and will accept a top mounted 240mm radiator I will stick with the XSPC RS240 that I have already purchased new for £20.
Thanks in advance
Questions -
Thanks in advance
