Case feet
Parsley
Hello everyone. I'm new to the case modding stuff and recently got an Antec 1200. I got it on a desk but I'm afraid it might get damaged on the bottom over time so I thought about getting case feet for it... and because it looks sexy.
Does anyone have any reccommendations as to what case feet are good? I've also heard of case stands and case dampers, are those better? Finally, would things like case feet be completely unnecessary or do they really have their benefits?
Thanks in advance.
http://www.mnpctech.com/casemodstore.html
Bought some feet from here for an older Chenbro case with top mount power supply. That 1200 looks like it has some glued on feet, and you would need to drill some 1/4" holes, and be sure they (screws&nuts) didn't interfear with the PS or other components....
Cheers for the replies.
I think I would be better off if I wouldn't have to drill through the poor thing. Those sticky feet look nice, but I also came across these: http://www.nexustechnologyusa.com/c/ntusa/rubber_case_feet_1.html and http://www.coolermaster.com/product.php?product_id=6128 . The Cooler Master one might be better seeing as it lifts it a bit higher and uses flexible rubber (or is flexible worse?). What do you guys think? Or should I do what this guy did http://img.techpowerup.org/080108/antec1200.jpg with the cushion underneath?
Seems these things also improve cooling of the case a bit though. Another problem is that I can't find either of those in any online shops nor at any stores. Guess I'll have to phone them up if I decide to go for those.
