Case Fans
Mentali$T
Hi i just wanted to know if anyone here has the thermaltake tsunami or really any case with fans in it and which way they have there fans. im getting temps for both cpu and mobo at about 36-40 degrees C idle. has anyone found a better way to keep the temp down by changing the way round there fans are? At the moment i have all three of my fans as they came.
edit: i know those temps arent too bad but i will be overlocking my cpu a bit so want to try and get it lower.
Thanks
Ok so i have tried a few different ways to have my fans and i have finally found the best one.
If you have the back one blowing air out, the side blowing in and front blowing in i now get temps of 35c for my cpu and 29c for my mobo. much better :)
