I am trying to figure out how slow I can go with case fans.
I have a Lian Li aluminum case which has 2 80mm fans in the front pull in air, 1 80mm on the top pushing out, and 1 80mm pushing out on the back. The PS has 2 fans in it (supposed to have 3 but the one on the bottom went bad and being a special sized fan I have replaced it). All of a sudden I have had 2 case fans go bad in a week so I need to replaced them and figured I might as well replace the rest while I am at it. I am running a p4 2.6 with a ati 9600xt and one HD. Not putting out a ton of heat but does anyone have any suggestions on how low I can go with fan output? I know the best way is to check the temp but since my fans are bad its not going to be a very accurate reading at this point. Any suggestions to what fans in general would be great as well. Thanks.
