Snakekilla
- Jan 12, 2007
Case:
http://www.newegg.com/Product/Product.asp?Item=N82E16811119103 (black version)
Goal: to use all the available places i can put fans onto the case...
says in the specs, its 120mm fans.. i checked in newegg, it shows 2 different kinds of 120mm fans square kinds and bit bigger smaller square ones.. bit confusing..
if u look at the image provided by newegg on that case, it should show the door of fans, i am assuming that is square 120mm fans, and i was wondering if was right on picking these fans out for my case or not..?
-- http://www.newegg.com/Product/Product.asp?Item=N82E16811998121
PS: the case should include 2 fans, 1 front and 1 back.. 4 on the door i think, 1 on top and specs claim that 2 more on the front i just cant see them in the images.. (total of 3 in front)
Specs adding into the case:
- CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X2048
- e-8800GTX 756mb
- e6600 core 2 duo 2.44GHz
- Thermaltake Toughpower 850W PSU
- western dig. 74gb Raptor 10k rpm
- Creative 7.1 Channels PCI Interface Sound Blaster X-Fi XtremeGamer Fatal1ty Professional Series
future changes, adding SLI 8800 GTX (adding 1 more to the one already have) and adding another set CORSAIR XMS2 2GB (2 x 1GB)
with the specs above, how many fans i should have to be stable in air flow? should i order cpu/gpu fans, and have all 9 spaces of case fans taken? or should i just have gpu/cpu fans only.. (n00b at fans) so please recommend me whatever method is best for use of fans to Stable my air flow in my new pc build (1st pc build)
- e-8800GTX 756mb
