board2death986
- Aug 13, 2005
I'm about to pull the trigger on a new i7 build, but I definitely don't want to stick with the stock cooling. I also need to get a 120mm fan for the HR-01 I'll have cooling down the CPU.
I want the case to be decently quiet but it doesn't have to be whisper quiet. I need a 120mm fan for the heatsink which should be the biggest performer, then I need another 120mm and 80mm to replace the case's stock fans, hoping for the type of fans that move big air without much noise, but if you guys have any suggestions that would rock. Also for the 120mm and 80mm if there is an LED variant that would be cool since i'm looking to use this thing as a night light
just kidding, but since this will be a LAN rig there should be some visual bling. and room is tight so I would rather not go the Cold Cathode route since that would mean more wires and hardware to cram into an already cramped case.
