So, I was thinkin about gettinga new VGA cooler, and along with it, I need some new case fans. My case is an antec SuperLanboy, and i've got the stock 120 mm cooling fans, which are apparently only 35 or so CFM. I really don't feel that much air flow in or out, and I have noticed higher temps due to heat building up inside.
So what is a good amount of CFM that should be going in and out of the case for efficient case cooling? Also, are there any major differences between single and double ball bearings?
I don't mind hearing the fans run, I just don't want it to drown out all the sound in my apartment, so any suggestions on fan models? Thanks
