Case FAN opinions needed!!
dVeLoPe
Bad Trader
I have some sort of problem with noise / efficiancy.... If the FAN will be LOUD it's got to have some sort of adjusting mechanism for idle / load settings...
I need the MOST CFM OUTTA ::
1x80MM Radiator Exhaust FAN
2x80MM Intake FAN
1x120MM Intake FAN
Please help hopefully with some fan upgrades and this water cooling setup I can get my temperatures from 59C full load @ 1.376V / 300x9 = 2.7 to some where in the low 50's so I can feal comfortable overclocking to 3GHZ +
well i cant click on the link...i did the damn intelilink ad over it...
but with water if it is halfway decent you can get in the low 40*C's
I have my x2 right now at 2.5 1:1 1.425vcore @ 33*C idle 38*C load....
dont get thermaltake water..... get a Petra's kit, he is a fellow [H]ard member,
http://www.petrastechshop.com/pecoel.html
both are good for CPU only ... the elite, more expensive will allow for addition of GPU block with no other mods... a singlee 120mm rad wont do well with CPU and GPU
a 2x120mm rad is perfect for a A64 or something like that with a higher powered GPU...
otherwise check out DangerDen.com
as for fans...
the yateloons that come with petras kits are good...
http://jab-tech.com/YATE-LOON-120mm-Case-Fan-D12SL-12-pr-3009.html
if you want more CFM and dont care about noise... check these out.... :)
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=49&products_id=20846
or more realistic...
http://www.svc.com/fba12g24m.html these at 7v are great fans...
for 80mm....
http://jab-tech.com/80mm-Panaflo-fan-H1B-MODEL-FBA08A12H1BS-pr-2004.html
more CFMs i have seen out of a realistic fan... panaflos are good fans and SVC is a cheap place to get them...
