I need some help/ideas/suggestions with my case fan setup.
Here is the case I am gonna use
RaidMax xA
As you can see, it accomodates 3 80mm fans, one up front, two in the back. I am thinking I should setup the fans like this:
LED fan up front, bringing air into the case
two fans in the back blowing air out of the case
Or should both of the fans in the back be bringing air into the case?
Would it make any sense to have the rear fans setup like this:
top fan, blowing air out of the case
lower fan, bring air into the case
Also, what are some things I should look for in case fans? Reason I ask is because I was looking for some and ran across these
Ultra Titanium 80mm 3-pk $19.99
Seeing as how my case come's w/the blue LED fan pictured, I'd only be using 2 of those fans, unless I modded the case to accept the remaining fan. Would that be a good idea? And if so, where should that fan be placed?
RaidMax xA
