Case fan configuration?
Copyright
Just got a Lian Li PC-G7B that has a front , rear, and side 120mm fan. There is also a top 80mm fan. The side, rear, and top are set to blow out and the front is set blowing in. Would setting the BOTTOM side fan to blow in be a better idea as only one 120mm fan is feeding the air for 3 fans blowing out and of course the PSU. My chipset is getting slightly warm so i think it could benefit if I make the side fan blow cool air in. Thanks for any input.
Nevermind, It dropped my chipset temp 7C and cpu 1C after reversing the fan.
