Case Dark Flash Knight K1 Fan Setup
Hi
I bought case and 7 fans. How to make good airflow? Dark Flash Knight K1 isn't typical case so i need some help. My setup is Gigabyte X570 Aorus Pro, RTX 3060 Ventus 2x 12GB, Ryzen 7 5800X, AMD Wrath Prism, 2x32 GB Ripjaws 3600 OC CL 16 DDR 4. In guide setup looks that.
Seems like a logical place to start. Are you having issues with temps? With it being such an open case the only other change I could see would be to just brute force it with intake and creating plenty of positive pressure, by changing the two "front" "top" fans to intake.
I didn't complete PC. Courier will deliver tomorow morning fans, M2, HDD and power supply. Thanks for advice.
id flip the one on the right to input so it hits the ram and you should be good.
