So I finally got a chance to put this Thermalright HR-03 on my EVGA 7950GT KO Superclocked today:
Looks nice and keeps the card very cool (even without a fan). Now I need to cut my case cover. I've never done this before. I do have a Dremel, but I've never used it to cut metal before. My PC is a Shuttle SD39P2 XPC. The case cover is a "U" type shell that you slide on over the chassis and secure with thumb-screws:
Which cutting wheel should I use to cut my SD39's case cover?
I need something to practice on first. Where can I get metal similar to the SD39's case cover to practice on? The case cover is pretty thin aluminum.
When I'm ready to cut my SD39's cover how should I do it? Do I need to put masking tape over the parts of the case cover that I'm going to cut?
What's the best way to measure the area I need to cut (I just want to cut a rectangular opening for this Thermalright HR-03)?
I'm going to be putting edge molding on the cut edges of the case later on. The corners of the rectangular cut (near the front) need to be rounded so I can get this edge molding all the way around the cut nicely. The cut will go beyond the back edge of the case cover since the HR-03 goes past the rear edge of the case cover.
What's the best way to keep the case cover secure (without damaging it) when I'm cutting it with my Dremel?
Any tips / advice on this would be very much appreciated.
