case cooling
4LC4PON3
DERP!
i need to get (2) 80mm fans and (1) 120mm fan and ive been told Yate loons are the best for the money. What makes them so good compared to others?
For the price, they are hard to beat for CFM to noise, they are made by the same oem that makes the Nexus fans. They are without a doubt better fans out there, but good luck finding some that are in the 4-5 bucks range, the Slipstream fans to me are the only other that are really worth a look at, but will run you about 7.50 a fan, however they by far out perform the YL fans. And have become my default choice when buying case fans that will not be horizontally mounted.
thanks for the tip. i ordered x1 120mm yate loon and x2 80mm yate loons from jab-tech. thanks
Let me know how them 80mm yl perform noise wise when you get chance, looking for quieter replacements for my htpc case.
