I have added some fans to my rig but my rear exhaust fan is weak.I am guessing around maybe 25cfm max.
I have a front intake fan about 34 cfm,a side exhaust fan about 30cfm,and rear exhaut fan about 20cfm.The side and front are both 80mm the rear is a 120mm.
Should I get a higher cfm rear exhaust fan?
I have a ati 4850 video card with the gfx chilla cooler mounted on it,it has 2 fans on the cooler I am gona guess they are 80mm.My temps dont go over 40 idle and 50 load on the card.
Wanted to know if I should get a high cfm fan like a 120mm scythe slip stream which produces around 110cfm for my rear exhaust or just leave it alone.
I have no clue about the whole pressure thing,I would figure getting the air out would be the most important but do you think my airflow is fine?
