BuddhistPunk
- Mar 21, 2002
I am in need of some assistance as hardware isnt my thing.
I have just put together a new machine that contains an ASUS A7V880 Motherboard, the case it sits in has a front panel that contains :
- audio in/out jacks
- 2 x USB
- 1 x Firewire (cant use as unsupported by motherboard, see note at the end)
This front panel has 3 (excluding firewire) groups of coloured wires coming out of it each ending in a bunch of loose sleeves. Each of these pin sleeves has a label:
USB 1
Black - gnd
Green - data+1
Red - vcc1
White - data-1
USB 2
Black - gnd
Green - data+2
Red - vcc2
White - data-2
Audio
Purple - r out
Yellow - r in
Black - gnd
Green - mic in
Blue - L Out
Red - L In
Black - gnd
Orange - mic bias
Now its blatently obvious that these need to connect to the relevant pins on the motherboard, the problem is that these pins do not have the same labelling conventions as the case cables so I am not 100% certain of what connects to what. The motherboard has :
USB Header (10-1 pin USB56)
USB+5V
USB_P6-
USB_P6+
GND
NC
USB+5V
USB_P5-
USB_P5+
GND
USB Header (10-1 pin USB58)
USB+5V
USB_P8-
USB_P8+
GND
NC
USB+5V
USB_P7
USB_P7+
GND
Front Panel Audio
Line Out_L
NC
Line Out_R
MICPWR
MIC2
BLINE_OUT_L
BLINE_OUT_R
+5VA
AGND
So can anybody tell me what should be connecting to what as I am tired of routing around the back on my PC for USB/Audio connectors
With regard to the firewire connection, the motherboard does not have an onboard firewire connector but the PCI card I have does and internal connector but this is a normal firewire style port and the case is just loose wires with pin sleeves - is it easily possible to wire up the panel wires to a bought connector?
Just incase these are the labels for the firewire
Black - gnd
White - vcc
Black - gnd
Red - tpb-
Green - tpb+
Orange - tpa-
Blue - tpa+
EDIT : if you are feeling really helpful
the motherboard manual can be found here :
http://www.asus.com/pub/ASUS/mb/socka/KT880/A7V880/e1654_a7v880.pdf
- 2 x USB
USB 1
Black - gnd
Green - data+1
Red - vcc1
White - data-1
USB 2
Black - gnd
Green - data+2
Red - vcc2
White - data-2
Audio
Purple - r out
Yellow - r in
Black - gnd
Green - mic in
Blue - L Out
Red - L In
Black - gnd
Orange - mic bias
USB+5V
USB_P6-
USB_P6+
GND
NC
USB+5V
USB_P5-
USB_P5+
GND
USB+5V
USB_P8-
USB_P8+
GND
NC
USB+5V
USB_P7
USB_P7+
GND
Front Panel Audio
Line Out_L
NC
Line Out_R
MICPWR
MIC2
BLINE_OUT_L
BLINE_OUT_R
+5VA
AGND
Black - gnd
White - vcc
Black - gnd
Red - tpb-
Green - tpb+
Orange - tpa-
Blue - tpa+
