That is a REALLY quick sketch of a case thats been buzzing around my head. The entire thing looks like an x from the "front" with the GPUs facing 45 degrees downwards. Given the shallowness of the case there is a hole over the motherboard which will utilize positive pressure to keep the dust out. This also allows tall heatsinks/GPUs to fit inside. The diagram doesn't reflect the dimensions but it is 19"x24"x30" (lxwxh). Each arm is also 7" in width. I'm not sure of some of the other specifics but tell me if this is at least feasible first.
Edit: http://www.scan.co.uk/products/3xs-isotope-mini-ix-chassis-bunka-uatx-inc-120gb-hd-1gb-ddr2-lg-dvdrw I found a retail case that looks like this albeit smaller.
