case cabel question, need fast answer.
UberPooner
Hi, i have a thermaltake armor case. at the top there is a place to plug in the firewire cabels. now for that cable they are each individual plug in's. instead of having like a whole block where i just plug them all in at the same time. they are like one pin at a time. anyway, the part of the case that connects to the mobo says for example TPB- and now does that plug into the TPB- part in the mobo or the TPB+. and another is TPA- does that plug into the mobo at TPA- or TPA+. you can kind of see what im talking about when i say the cabels are all split from this picture http://www.newegg.com/Product/ShowI...WS+Black+Full+Tower+Case+w/+25CM+Fan+-+Retail
its the 7th one over. Well my case is open and im waiting for a reply, thanks
