Case Buying
Malikman
Does anyone know of a case that has removable mobo tray,side window w/ side fan that also has front usb,audo and/or firewire that has 2 internal 3.25 (for hd's) and is screwless/toolless case
That's what i want minimum in my case is that possible... i've been looking and found nothing anyone know of any cases that are good that are close to what i want or are what i want??
i know it's not pricy compared to what cases can get and with all the fans etc. (fan spots) it comes with i'm sure it is well worth it but i was wondernig if it was possible to get a case of what i wnat ... for like 40-50 lol i know it dodesn't seem like much differnce but yea.. i'm assuming not but yea :) also any other case suggestions would be nice :-D
the Lian-Li V2000 is more expensive becuase it's full-tower (or at least the one i saw was full tower) i'm lookin' at mid-tower or maybe a small case so it's easily portable as a desktop can be.... suggestions for those (more portable cases for desktop) would be nie too
http://www.directron.com/860bw.html
I think this is the one for you, if you want cheap, removable MB plate, removable 3.5 cage, and sidewindow. Only thing don't have is the front USB and firewire, which you can get a front control panel with those extensions. IMO, you rarely find a removable MB tray for less than $70. So if you want cheap, you got to compromise. For $33, this is case for you, mod a little to get some usb or firewire connector to the front will only take you little bit of effort.
ok yea i'll have to shop around i may end up getting a 60-70 dollar one who knows.
Don't know if this has all the specs you're looking for, but this would definitely be worth looking at, especially if you want some quality without paying high price. case link
As far as the window goes, you're in a case modding forum, so you should be willing to at least consider making your own window!! ;)
yea i am considering and i'm sure it would be cheaper :) just would have to figure out were a cathode would go for sweet lightage :-p
would you have anything like http://www.dealsonic.com/skmssialatxm.html but maybe in black with toolless ? :-D i know i'm stretching the limits of everything a case has haha... i'm bascialyl looking for mobo tray/REALLY GOOD Ventilation so proc and stuff is real cool/tooless i can add the window later...
This other forum i have been asking on this one guy recomended the kingwin kt 424 and that one seems really good. I was trying to see if i could find those exact crap but w/ all clear that would be awesome... haha but the kingwin kt 424 seems really good... removable mobo tray,black,window,screwless .... if anyone has anything that can beat that and stuff :) i think that seems better than the one you are suggestion tho but your thoughts are always appreciated that's why i made a forum :-D
