Case and cooling help.
Yate loon 120s are nice. Nexus are really nice, but expensive. As for the 80mm, Panaflo L1A are my favorite, they move a good amount of air and are really quiet.
Thats a cool case for 67 bucks man. I have heard some good things on the Vantec Stealth fans, however, I am waiting on ups (today) to bring me my Panaflo's so.. I am not that much help... I have 2 enermax 80mm and a 120 enermax that I am taking out tomorrow. right now I have 4 80mm and one 120. I plan on having 2 80mm only tomorrow.
That was is very cool as well! Since the last I looked, cases all modded out are very cheap!
Very much so. I recall when just a window in a case window would cost you up the ass..now you can get a case all tricked out for almost nothing. I wish that case would fit a top my MACH II. Only thing I hate about it; lack of ability to just use any case to sit on top..it has to smaller then a reg case. :(
I like the little vent mod deal on that one I listed, for cpu exhaust or intake.
I got my Lian Li in 2001 with the window and cold cathlode for 270 bucks. Plus I had to install the window which was a mofo!
pollution29 said:
Hi, I am building a computer for the first time and I was planing on getting this case.. http://www.newegg.com/app/viewproductdesc.asp?description=11-105-113&DEPA=1. I plan on adding two more 80mm fans. My question is.. will this keep my system cool enough?
Adding fans will, obviously, help reduce the heat in your system, but get the largest fans that you can - not only do they push more air, but they'll run quieter. If you don't give a rats ass about noise, get a high CFM delta. If noise is something you care about, get panafloes or vantec stealth.
