Radio_Silence
- Oct 29, 2005
I am in the process of building a new gaming rig and need advice on a case. Specs are as follows:
- AMD SanDiego 4000 (I know - should have bought the 3700)
- Zalman CNPS 9500 Cooler
- Asus A8N32 SLI mobo
- Cosair XMS 3500LLPRO (2GB)
- (2) eVGA 7800 GTX OCs
- Creative X-Fi Xtreme Music
- PC Power & Cooling 510 SLI PSU
- (4) Hitachi Deskstar 250GB SATA hard drives
- Plextor 716 AL/SW
I am currently using a Cooler Master ATC-110 in my existing system. I had planned on putting the new components in this case but was worried about the cooling, especially since I plan to OC. The ATC-110 only has four 80mm fans. Of particular concern is that there is only one 80mm rear exhaust fan.
Will this case provide adequate cooling if I replace the fans with something that produces more airflow or should I look at buying another case?
I had looked at the CM Stacker but despite the incredible cooling potential, I am very unimpressed with the asthetics and am worried about potential noise levels. Another option was the Silverstone TJ03 but that seems to be just an upgraded ATC-110 with an additional exhaust fan. I would love to have a TJ07 but it won't work with the heat pipe cooled Asus mobo.
In short, should I replace the ATC-110 and, if so, what case do you recommend?
Thanks for you input.
- Plextor 716 AL/SW
