Hi All,
Advice needed. Currently I am in the process of choosing the parts for a new system and required some case advice. In contrast to other people on here my main need is for a powerful virtualization host system for testing and IT certification purposes.
That parts I have chosen so far are:
- Intel Core i7 920
- Gigabyte GA-EX58-UD5 Motherboard
- Corsair TR3X6G1333C9 6GB (3x2GB) DDR3, two kits 12 GB total
- Noctua NH-U12P SE1366 CPU Cooler
- Western Digital Caviar Black 750GB WD7501AALS two drives
- Antec Signature Series 850W PSU
- Sony Dual Layer AD7200S0B SATA Black DVD
- Gigabyte GTX260 OC (Core 216)
- 64-bit MS Windows Vista Ultimate
The tricky problem is what case should I chose? I value silence and wish to go as quiet as possible with clean sleek lines. The case must also have air filters and be able to deal with ambient temperatures of around 32 degrees centigrade. I am worried in particular about cooling the 6 memory modules over the Australian summer. I have also selected the motherboard so that in the future I can run 24 GB of RAM so keeping the memory cool is a must I believe.
I prefer the Antec products currently the favourite being the P182, however will the memory remain cool with the fans on low with an ambient of 32 or should I get the Antec 1200 for its greater airflow?
Other cases I have looked at and ruled out are:
- Antec 900 = No dust filters so no go.
- CoolerMaster HAF 932 = No dust filters so no go
- CoolerMaster Cosmos 1000 or S = Over priced and I prefer steel
- SilverStone TJ09 = Over priced and supplier out of stock
- SilverStone FT01 = Over priced and awkward fan filters.
So what case should I get Antec 1200 v P182 ??
- Intel Core i7 920
