Case accommodating RTX 4090 as well as 3.5" drive bay stack?
sphinx99
I'm largely resigned to the reality that a 4090 FE is not something I will be able to source, which may leave me to deal with a much larger card. My current case, a Define R6, absolutely will not fit such a card. Part of the problem (I think) is that my use case needs room for a stack of minimum 5 3.5" spinning hard drives, and I want these drives to receive a decent amount of air flow. I know that cases, including my Fractal, have removable front drive cages that would easily accommodate a 4090. However, I do need those cages.
Looking for suggestions on a high quality case that could accommodate both 4090 and spinning storage. I'd appreciate any leads, as I head off to the computer store to see what options they have.
i would use neweggs search to narrow it down and then shop around for best price. phanteks larger cases mostly meet what youre lookin for
Define 7 XL got the job done. Probably the single most pleasant, flexible, clever and high quality case I’ve ever worked with. There is no configuration I can think of that it could not support.
