velusip
- Jan 24, 2005
I've been using a Netgear router for nearly a decade now and it works beautifully. I needed to add some wireless to the mix. I didn't want to have to switch to anything else, but the pain that this Orinoco AP has caused me made me go buy a preconfigured wireless router...
I purchased an SMC wireless router because of the lack of compatibility issues with the wireless among friends. It's true, no problems whatsoever with the wireless. It even cascades off the Netgear, however DHCP is completely destroyed and since the wireless features cease to work once you disable DHCP as well, it's pretty much completely useless. I don't want to flip the routers around either since the netgear does a much better job of port forwarding through NAT. Basically the Netgear is way better, and I don't want to completely phase it out.
I was wondering if instead of cascading the SMC as a switch, could I simply plug the WAN port of the SMC into one of the DHCP distributed ports of the Netgear? I've wondered this for a long time, but never bothered trying it.
It would look a little like this:
Netgear RT314 (WAN: x.x.x.x, LAN: 192.168.0.1)
SMC WBR14T-G (WAN: 192.168.0.2, LAN: 192.168.2.1)
I'm about to try it, but I figured perhaps someone out there has done this and could give me some tips. Perhaps if I should disable RIP among other things on the SMC. Tips welcome!
