Carrying Harness
devman
I might be going to a LAN party in the near future, and I was wondering about carrying harness' for cases. Can anyone recommend any good ones, for a case about the size of the Antec Sonata II (mid-tower)?
16.75"(H) x 18.25"(D) x 8.13"(W)
42.5cm (H) x 46.3cm (D) x 20.6cm(W)
I'd guess 30-40 lbs. (13.6-18.1 kg)
Other Specs: http://www.antec.com/specs/SONATAII_spe.html
Alot of Antec cases should come with a carrying strap...I know my Super Lanboy did...
I believe the only case Antec makes that comes standard with a carrying strap is the Antec Lanboy. Antec used to make a carrying harness that was called "lanpal" iirc, but I guess it was discontinued.
Anyway, the hunt goes on, anymore info would be appreciated.
If you look in the for sale forums you will find people selling the case strap that came with the DFI Lanparty's. I got one Amdmb.com forums for like 12$ shipped...funny that i now have a DFI lanparty board that didnt come with one =)
The Antec case strap is alittle smaller i belive. It is meant to be used with the Lanboy, which is smaller then normal full towers.
I used the DFI strap on my Cheiftec Dragon case and my CM im using now. Both fit np problems with room to spare.
