Cardkey System Exploited via Android App
How do you get the ip addresses of these doors that sit exposed on a wireless network?
You need the IP address of the cardkey system to do it, is there a way to get that without inside info?
I know someone who should really see this.
This is very unlikely...
I work with the Johnson Controls version of this and at this location its all done on a internal lan. unless this hacks the vpn then the control server, I doubt this works. I would like the software to to test it out though.
you would be better of using a high powered electro magnet that you can manually over power the solenoid with.
I had a keycard like that at work. I broke it apart once and all it had was some copper wires coiled up inside.
Reminds me of good ol' Deus Ex.
Hmm, speaking of, I think I'll install that again! Who cares about graphics when it's an awesome game!
FAKE and i can tell you why. I install access control systems for a living. Heres how they work
The access card reader is connected to a controller, and this controller talks to a "database". Within that HID card is actually a coil of wire and a little ID chip. That stores the ID number of your card. When you scan your card, the ID number is sent back to the controller and the software verifies if its okay or not to unlock the door.
So the card reader has no IP. Now the controller MAY have an IP, but typically they are NOT on the internet. We do have a system that can be accessed via the web, but it requires software and other configurations. You cant just send a password to an IP and have it unlock, because the IP has nothing to do with it. The software has to know WHICH reader read the card number... so it wouldnt work at all.
100% fake.
I still highly doubt it. If anything he'd have to be on the same network as the controller/device, and the device would have to be the most piece of crap system out there. I do this all day and frankly doubt its real. But again, theres a SLIGHT chance it could be real but HIGHLY doubtfull... too many factors have to line up... and if they all line up, you wouldnt need an app to do it anyway as you'd have access to the access control system anyway... so basically IF you have access to the system, you could i guess potentially do this via an app, but like i said, you have to be on the same network. Theres no tunneling in over the internet and no walking up to some random door.
Here's a better video:
http://www.engadget.com/2011/03/17/caribou-android-app-opens-doors-over-the-internet-needs-neither
I sent the guy who did the xploit an email asking him for a little more info on the circumstances.I didnt ask for the app but asked if he was on the same network as the panel and which kind of system it was (because it could be some ancient system that has no security what so ever)
The systems I install sit on servers that run SQL databases and you cant just send a command to the database to open a door, the software talks to another server program that in turn talks to the controller, which in turn, opens/closes a relay on the board to open the door. Lot more complex then sending a command to an IP to unlock a door.
Id like to assume each of those access devices is a SINGLE device with a SINGLE IP, and that they DONT talk to a central access control server... only thing i can think of for it to be legit at all.
Granted I don't have a TON of experience with gated properties and what not , but of the time share places I've been to I usually find the gates to be so low that I can literally reach over them and unlock from the other side that doesn't require a key card
Sounds like the same system we use.
I agree either this is a really shitty card access company or the people that setup the system are retarded.
So you are saying if I use my droid I can stay at hotels with free wifi and keycard system and have access to everything and pay for nothing. That if the server is on the same subnet as the wifi. I can see vacationers being robbed blind once they leave to room.
this
brute force baby, like the guys with the truckloads of amplifiers say "there is no replacement...for displacement"
100% fake.
Anyone can use a screw driver and a drill to install something. Do you support these systems also or just install em?
That app looks just like hacking a Wi-Fi system. The access point connection was established and gained access to the system (looked like no security was in place for the Wireless) and then used the software to command the gates to open.
Those key readers looks wireless to me.
Lame, not available to the public. I was going to ditch several of the key cards that I have to carry and just use my phone. Nothing like standing outside your apartment building in the rain because you have forgotten your key card and the stupid desk attendant has wandered off.
We install/support the systems. 100%. We actually did the access control system on the U.S.S. Intrepid... yes thats the big battleship in NYC. That was an interesting job.
But yeah we don't just take it outta the box and throw it on and go "ohh well good luck" we actually know what we're doing.
Now don't get me wrong, there are simple systems that don't take much brains to install, chances are the system they "cracked" was one of those really simple systems that don't have much security. But we don't use those systems... well no thats not ACCURATE, we DO use those very cheap systems for clients who want to save a ton of money and only have a very specific small need, but we definitly DONT put them on the public internet for anybody to crack into. Thats just foolish really.
Ohh i have a solution for you then :) I don't really carry a keycard anymore (i mean i DO because i have so many systems i install and have many types of cards)... but i have a card installed behind my phone... what i did was took one of the standard HID proximity cards and took it apart. This should work on all cards, but the HID ones (as shown in the video) are thicker so they are easier to take apart. Heres whats inside:
So all i did was took out that wire/chip and put it behind my phone (i cut the plastic around it so the wire wouldnt get bent up)... works great.
Heres an image before i cutout the circle (i didnt need the extra plastic so why not cut it out)
Ohh theres also bluetooth readers... but unless your in charge of the system at your complex, you cant just put one in... it replaces the standard reader (or gets installed near the existing reader) and then any bluetoooth device can get programmed in. You basically put the bluetooth phone near the reader, READ the card (which it'll DENY at first), then in the software you see what your bluetooth ID is and you program that... works great.
Problem is if you walk near the door, it'll open up, lol. We did this for one client who wanted it. We put reader in ceiling above
100% fake.
A lot of these card readers can be put in standalone mode that do not go into a controller.
Awwww, I thought we were going to be able to have some fun at work but I highly doubt our system is exposed like this.
I had a card key like that for a lab room at school (one with the wires coiled up inside). I had it in my wallet when I went through the x-ray machines in the airport a 5 or so years ago. All the dude that was running the machine did was ask me what it was and tell me it looked really weird under the scanner. If I tried that today, I'd probably get a good strip/cavity search.
This isn't especially related to the topic at hand, but it did make me remember the incident.
I loved that game haha, its been a while since I have played it. Good ol' Multitool.
On a side note, it appears that the gates also have a mechanical lock on them as well, so if that is locked there is no getting in unless you pick that, and get past the electronic portion.
*snip*
*snip*
I gotta admit, it's the simplicity of the idea that makes it so damned brilliant. Reminds me of this quote:
"Simplicity is the ultimate form of sophistication." -- Leonardo da Vinci
Absolutely brilliant idea... ;)
I went through JFK airport security last week... no problems. I also did this last year as well, never stopped yet. I bet it does look funny under the x-ray to see a phone and a coiled up wire, lol.
If they don't stop you, it makes me wonder if the security people running the x-ray scanner know what to look for? Suspicious and odd wiring? Check go right ahead sir. Suspicious wiring where it shouldn't be? Go right ahead sir. Wait wait wait... your wearing shoes that are loafers onto an airplane? strip-search.
I like how he just arrrogantly throws the key card away...
I also noticed a sequence of pin numbers being tried in the readout on the phone.
Looks brute force to me. I'm sure it's possible with just a bit of information and if they
have a wireless lan on the property and it's on the same subnet it wouldn't take
much to do a quick IP scan.
You'd be surprised how many businesses use defaults for IP and security setttings.
I'm 95% sure the system we have at work is airgapped from the main company lan. You'd need to partially dismantle the box to get any access to the network; and I wouldn't be surprised if the readers are tamper resistant and tell the server to disconnect them if you try.
Guys, these were gates at a damn swimming pool. They probably installed the cheapest, easiest to deploy system they could get. So, IP wireless readers (in the clear of course) talking to some dumb box that controls them using an easily spoofed protocol.
Hell, if he had the docs to the system this would be about a 1337 as connecting to wifi at Stabucks.
Let's see him repro this at a real target. Say Google, Intel or Microsoft.
the card access we use sits on an internal LAN. & we have no wifi.... so... this wouldn't work =P
I did work for a small manufacturer of access control systems. They had a tcp/ip solution for one of their smaller (cheaper) control panels that sent all the data packets back and forth totally unencrypted. Most of their clients did not use a private lan for this, and since that system did have a command to open a door, this is at least theoretically possible. From the looks of the video, this system was being used by an apartment complex or something to restrict access to a pool. That's just the type of customer that bought this particular system. So while it's unlikely this person reverse engineered the data protocol being used and figured out how to send the door-unlock command, it is possible, just not likely.
