Card Upgrade
-(Xyphox)-
Ok, i am thinking of upgrade my Vid Card on my Main System, Specs in Sig.
Any idea's on what i should look into,
Also if a vid card is 16x, and i dont have an Express slot on my Mobo, can i still use it?
Any idea's on what i should look into, Also if a vid card is 16x, and i dont have an Express slot on my Mobo, can i still use it?
1)how much are u willing to pay?
2)nope
2)nope
Cost really is not an issue for me, i make enough
But want to keep it under 500 if possible
Bs CIS, MCT, MCSE, MCSA CNE, CNI, Net+, Security+, CCNA, CCNP:CP:
With those certifications, you should know the hardware stuff and be able to answer your own question.
well then it depends on what u wanna play .. if u love doom 3 then get an ultra .. if u love half life 2 get an xt pe if u can find one or an xt would do it... or if u can find a x800 pro vivo then get that and flash it ..
if u wanna get a card that has good performance at a good price ... get the 6800 gt
it's all ,pretty much, up 2 u ...
ok thanks for the info, i am looking into an 6800gt, and maybe an x800, depends if i want to goto major gaming or not
generally the 6800GT is 'better' than the x800Pro...as hard as it is for me to say :( (<3 ati) but if you can flash it to a PE then the Pro VIVO would be alot better. but this is risky and you have the potentiality to temporarliy have no graphics card...:)
Right at this moment unless you can find an X800XT for less than $400 then i would just go the 6800GT ;)
